Always has a mesa error
gutenburg
(@gutenburg)
updating prusa slicer causes mesa errors that can't seem to stay fixed. At this point I can't recommend prusa at all. I spent a lot of money on a Prusa XL and I spend more time on the fixing the slicer then printing. Chat keeps running me through the same steps and I still have the same problems this needs to be fixed now.
Napsal : 22/04/2024 1:47 am
What are the errors?  It may depend on the GPU you have fitted and any settings/optimisations you have made for, for eg. particular games...
You may do better asking on a mesa group about the specific error codes.
Napsal : 22/04/2024 8:41 am
gutenburg
(@gutenburg)
RE: Always has a mesa error
The first version of slicer I used (2.7.1) was stable after I moved the dll into the application directory. The error says that it wants me to run using software rendering. Every version since requires that I uninstall, manually delete the application directory and remove the application directory int the user roaming directory. Even then some times I have to re-install after random periods. The graphics card is out of the box. No extra changes. I'll probably quit trying to update slicer.
Napsal : 23/04/2024 10:57 pm
