All my presets, user configs, print profile, build plate and 0.4 mm tip are all gone.
vhcconstruction
(@vhcconstruction)
I am running slicer 2.3.3 32bit on a dedicated offline system.  Today I went in and was going to print something and everything is gone.  I run .25, .4 and .6 nozzles, all that is there today is the .25 and .6, even though in config the .4 is checked.  Even the build plate is gone now just a hazy square plate.  I cannot find any backup or anything.  The only driver on the system that has been updated is the graphics card driver.  I am at a loss, 4 years of tweaking are gone, all config snapshot come up with the same profiles and if they were all re written.  I pull up the .4 and .6 snap shots and all that comes in is a .25 and a setting that I never saved.  I am at a complete loss, it is like it was wiped away.  Any help would be greatly appreciated.
Posted : 03/12/2024 11:54 pm
3Delight
(@3delight)
Moderator Moderator
RE: All my presets, user configs, print profile, build plate and 0.4 mm tip are all gone.
Have you checked if the Config folder is there? (C:\Users\*USERNAME*\AppData\Roaming\PrusaSlicer).  If it's there inside it you should see a folder called "snapshots" and in that are backups of the PrusaSlicer sub-folders named for the date the backup was made (Eg. 20240905T173827Z).  Just drag and drop all the folders into C:\Users\*USERNAME*\AppData\Roaming\PrusaSlicer and overwrite what's there and you will have restored the backup.
Alternatively in PrusaSlicer look under [Configuration] -> [Configuration Snapshots] and activate a stored backup...
Posted : 04/12/2024 12:04 am
vhcconstruction
(@vhcconstruction)
I tried that, all the file are dated the time I opened slicer today.  And loading the snapshots all bring in the same config, nothing close to what they were saved as.  Honestly it is like it just wiped itself.
Posted : 04/12/2024 12:41 am
_KaszpiR_
(@_kaszpir_)
Try searching files under windows restore point, if any
https://support.microsoft.com/en-us/windows/system-restore-a5ae3ed9-07c4-fd56-45ee-096777ecd14e
Posted : 04/12/2024 12:50 pm
