Align Inner and Outer Seam
shanehimself
(@shanehimself)
Membre
I am trying to print some Lightsaber blades (sequentially hence the layout) and when I do I'm trying to align the seam on the inside and the outside of the print. For some reason one of the models (the middle section) has the seams on opposite sides of the tube. I can select "Avoid Crossing Perimeters and that will prevent the travel across the center of the tube however I'd prefer they were aligned...or at least closer. I can't seem to figure out why the other four work like I want. Any suggestions would be very much appreciated. If I only print one blade at a time, the number 3 blade always does this.
Without Avoid crossing Perimeters checked. With Avoid Crossing Perimeters checked.
Publié : 21/12/2023 3:41 pm
