Advice needed to reduce filament catching previous layer
SubseaUK
(@subseauk)
Hi, as a fairly new user I am having issues with printing the infils on key fobs. the first and last layers seem to be fine and give a good Finnish but on the infil layers the plastic seems to catch. I have been advised to change the pattern which I have done but it has not cured it.
I have attached a 3mf file if this helps.
Any assistance / pointers greatly appreciated.
Cheers
Posted : 27/01/2022 5:09 pm
sylviatrilling
(@sylviatrilling)
RE: Advice needed to reduce filament catching previous layer
Yes, a .3mf file is always helpful, but yours didn't get attached. You need to ZIP the file or the forum won't attach it.
Mk3S+,SL1S
Posted : 27/01/2022 5:20 pm
SubseaUK
(@subseauk)
Thanks sylviatrilling will zip and reattach now
Posted : 27/01/2022 6:25 pm
SubseaUK
(@subseauk)
RE: Advice needed to reduce filament catching previous layer - 3mf now attached!!!
Here is the missing 3mf file
Posted : 27/01/2022 6:27 pm
sylviatrilling
(@sylviatrilling)
You could try reducing the speed of the infill. Infill goes at a relatively high speed, but because your items are so small, the infill layers might not be getting enough time to cool and solidify enough before the next layer comes.
Mk3S+,SL1S
Posted : 27/01/2022 7:19 pm
SubseaUK
(@subseauk)
Thanks, I will try that.
Posted : 27/01/2022 7:21 pm
