Additional perimeters around holes
Hi, I have a design were I want to reinforce a couple of through holes with a thicker wall. I’ve tried a cylindrical modifier with more perimeters which works for the hole, but it also adds new perimeters at the outside edge of the modifier cylinder. Anyway around that?
Thanks
Napsal : 18/09/2019 3:30 pm
RE: Additional perimeters around holes
If you stop the cylindrical modifier about 1 layer inside the model then you should get what you want. See this blog entry, there is a section called "Local strengthening of the model" that describes exactly what you want: https://blog.prusaprinters.org/model-with-prusaslicer-modifier-meshes-tutorial/
See my (limited) designs on:
Napsal : 18/09/2019 5:51 pm
