adding unknown printer anetet5x
minaspus
(@minaspus)
having problem with anet et5x into prusa slicer any one know what firmware the anetet5x printer uses after getting setup does not extrude filament what did i do wrong
Postato : 28/10/2020 2:48 pm
RE: adding unknown printer anetet5x
Could you save one of your projects as a .3mf file (project >save as) and then take the 3mf file and zip it up and attach it here. Needs to be zipped or the forum won’t accept it. Any model will do, as ling as it’s one that isn’t working. The 3mf will contain not just the model but all the print, filament and most importantly the printer profile you are using. We can then take a look for anything obvious.
A bit of research shows that the ante et5 uses firmware based on Marlin but I was unable to find out what version so it may be based on an older version.  So there shouldn’t be any problem getting it to work as The Prusa printers also use a Marlin base for the mk3.
You are probably missing some appropriate start gcode but as I say once you post a project we can take a look.
Postato : 28/10/2020 4:07 pm
Wilko hanno apprezzato
