Adding multiple commands to the same layer Slicer 2.5.0
I want to set up a print with a colour change and a nozzle temp change on the same layer. When I add one of the commands to the layer the option to add another command disappears. Am I able to do both actions simultaneously, or do I have to apply my temp change to the next layer?
TIA
Opublikowany : 30/11/2022 8:22 pm
RE: Adding multiple commands to the same layer Slicer 2.5.0
Instead of adding a colour change use the add custom option and then in the field just add the sequence of commands you want. So you can add both a colour change and a temperature change. Or any other block you want.
Opublikowany : 30/11/2022 8:25 pm
