Add Default Model To Start Of All Prints?
Is there an option to add a model to the beginning of a print by default? For example, printing a small coin right after the purge line, but before whichever file is being printed.
Would I need to consider inserting that model gcode into the "custom start G-Code?"
Thank you for your time.
RE: Add Default Model To Start Of All Prints?
Not heard of this,
Probably best to consider saving a project with your coin already in the desired position.
so when you start a new model you open the project file,
then add your other models and use sequential printing to ensure that the coin prints first, if that is important.
I suppose so. I'll try updating an STL with an offest origin point and add that to the Shape Gallery. That way I can add it without adjusting the position. Thank you for the response.
