A modified STL for two extruders
Hi, Is there any way, from a SINGLE STL file, to configure it for 2 extruders?
I don't want to create two separate files and then merge them.Instead, I want to create one and then configure which parts to extrude.
without using the painting tool suggested by the program. Is there any other option?
If not, is there any other program that makes this possible?
Opublikowany : 01/04/2025 3:17 pm
RE: A modified STL for two extruders
Depends on the STL. If the model in the STL file consists of different parts, you can import the single STL model and use Split to Parts, then assign the parts to different extruders. If not, you're out of luck.
Opublikowany : 01/04/2025 8:07 pm
