2.9.1 Breakaway Interface Questions. Speed over alternate material
JC
 JC
(@jc-3)
I have a question about the new Breakaway Interface print settings profile.
Background
In the past, I've adjusted the "Top contact Z distance" to a small non-zero value (0.001). This allows the next layer to print at lower bridge speeds. This helps prevent breakaway material (like PTEG on PLA) from not sticking and pulling away at normal printing speeds.
Question
Does the new Breakaway Interface profile adjust (or have a way to adjust) printing speed over less sticky support material? It doesn't seem to, but maybe the new speed settings handle this?
Appreciate Your Insight!
Publié : 12/03/2025 3:07 pm
RE: 2.9.1 Breakaway Interface Questions. Speed over alternate material
You can use the Compare Profiles option in Prusaslicer (the three circle icon next to the padlock) to compare profiles. As far as I can see there's no real difference (but I also didn't spend much time chasing this down)
Publié : 12/03/2025 10:29 pm
