2.9.0 Snap Connector Separated in Slicer
Flowerpool
(@flowerpool)
 I tried adding snap connectors to a large part to get it to fit in the build plate. There are 4 locations that have connectors.
Only one of the connectors is sliced incorrectly, separated from the part with perimeters. All 3 other connectors are correctly sliced with the connector fully integrated into the body of the part.
How do I fix this? I did not catch it in time, and now it is printing with the connector separated from the part.
This topic was modified před 1 year by Flowerpool
Napsal : 28/12/2024 9:04 pm
Files > Save Project as
Napsal : 29/12/2024 1:21 am
Flowerpool
(@flowerpool)
RE: 2.9.0 Snap Connector Separated in Slicer
Thanks for the response.
See file here:
CaseMount1ExportTest
I figured a workaround where I cut the connector off and then nudged it slightly into the part.
Napsal : 30/12/2024 5:35 pm
Yes, for some reason the cut plane appears to have lost contact with the surface; I've no idea how that could happen.  In this position I would use dowel connectors, probably hexagonal and then I would print the dowels lying flat on the print sheet.
Napsal : 07/01/2025 2:36 pm
