2.8.0 forces a reslice when I try to add a pause (or gcode)
Mcarson
(@mcarson)
Title says it all.  Same problem occurs if I try to add M601 as a custom gcode.
It works ok the other half of my project.
I just installed this version to use the organic supports and save myself 5 hours of support time.
However, I can't get it to stick; once I enter the pause message it forces a reslice, which of course deletes the pause.
File attached.
thanks
So many settings and I'm not doing anything unusual so I can't do anything special.
Posted : 18/09/2024 5:08 am
RE: 2.8.0 forces a reslice when I try to add a pause (or gcode)
No file attached.  To attach a file you must ZIP it up first or the forum just silently doesn't attach it.
Posted : 18/09/2024 6:43 am
