2.8.0 Bridge blobs
nivekmai
(@nivekmai)
2.8.0 Bridge blobs
Just updated to 2.8.0, and almost started a print when I noticed something odd, so I split the model down to just the problem area:
I tried printing it just to see if it was a render problem, and it indeed spit out a massive blob instead of a proper bridge.
I attempted to export my config to ask for help, and found that my "bridge flow ratio is out of bounds". Looking at that setting, it seems (at least with 2.8.0) it should be 0-1, but mine was set to 100. As far as I know, I never set it to 100, and definitely would have noticed that all bridges just dump blobs, so I think it must be an issue when upgrading to 2.8.0 with existing configs.
Resetting the value to 1 seems to have resolved the issue.
Opublikowany : 06/08/2024 5:14 am
RE: 2.8.0 Bridge blobs
There were a couple of such reported on the PS github during the early betas.  That setting has always been 0-1 on PS though.  with 0.95 being common in some profiles.
The specific ones reported always seemed to be from profiles and projects created/used with other slicers such as Super slicer or one of the other forks.
Opublikowany : 07/08/2024 6:50 am
nivekmai
(@nivekmai)
Ah, my profile is originally from superslicer, but I've been using prusaslicer for a year now.
Opublikowany : 07/08/2024 3:35 pm
