2.4.0 startup issues on ubuntu 21.10 on Framework
ga
 ga
(@ga)
Running 2.4.0+linux-64-GTK3 on linux 21.10 on a Framework laptop.
When started, I get the message:
(prusa-slicer:2626): Gtk-CRITICAL** : 08:48:38:686: gtk_window_resize: assertion 'height > 0' failed
I then get the "this the first time prusa-slicer has been run" message asking if I want to send the configuration.  If I select to send the configuration, the dialog stays up and I never get any further; I have to kill the process.
The framework has a display which is 2256x1504, but normally runs at 200% magnification, so half that.  I tried running at 100% and get the same messages and problems.
Is anyone else seeing this?
Opublikowany : 26/01/2022 4:08 pm
