100% infill offset between layer..?
Julienhirsch
(@julienhirsch)
Hello the community !
I would like to print a very clear part, and I'm searching to create an offset between layers, I explain :
I print all layers with the same orientation.
Between each layer, I want to print betwen each lines of one layer( in yellow) of infill of the previous layer (in red):
In this case, I avoid to have air bubbles between lines and I fullfill the part to have the best clear part.
Is it possible to do it with PrusaSlicer?
Just for the purity of image I want to make : 😍
Thank you in advance !
Veröffentlicht : 07/03/2021 5:10 pm
RE: 100% infill offset between layer..?
No, there is no setting to do that.
Veröffentlicht : 07/03/2021 7:14 pm
Julienhirsch
(@julienhirsch)
There is no other solution to do that? Maybe other software or tips?
Veröffentlicht : 09/03/2021 11:41 am
Not that I have seen.  If you find something let us know.  Personally that picture you posted is as clear as anything I've seen from a fdm printer at that scale.
I've seen thin sheets/areas that were over extruded somewhat to force the extra plastic into the interior gaps and then post processed on the surface to make them smooth, but nothing complex in shape like that motor mount.
You could always open a feature request explaining what you want on the Prusa Slicer github. https://github.com/prusa3d/PrusaSlicer/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc   it might get done sometime in the next decade lol (there are over 1600 open issues).
Veröffentlicht : 09/03/2021 1:39 pm
Julienhirsch
(@julienhirsch)
Yes, this part is beautiful!
I will try several times until it works!
Veröffentlicht : 09/03/2021 4:17 pm
