Napsal : 19/10/2025 3:20 pm
RE: スライサーを実行すると,なぜが、添付画像の様になってしまいます。解決方法を教えてください
I assume you mean the little green triangle on the edge of the model?
First, try to print the model upside down or on the side. https://help.prusa3d.com/article/move-rotate-scale-tools_1914
Another option is to paint places where t you want supports to be, or block areas where supports should bot be created. https://help.prusa3d.com/article/paint-on-supports_168584
Napsal : 20/10/2025 7:08 am
