INDX Filament mounts
Randy Hearn
(@randy-hearn)
Membre
Ordered the INDX and have been reading/looking at the specs. But I do not see what spool mounts are coming with the base INDX unit? The pictures show it build with 8 USS Dryboxes but not clear they are included and not in the BOM I saw.
Anyone know what the base mounting will be for the 8 unit filament, or should I get 8 USS Dryboxes on order now to have when my upgrade gets here.
Publié : 05/05/2026 4:09 pm
Scotttomo
(@scotttomo)
RE: INDX Filament mounts
Posted by: @randy-hearn
Depending on what configuration you ordered, 4 or 8 tools, decides your mounting option. I believe you should get the necessary spool mounts for the sides of the C1, for the number of tools you buy, although I could be mistaken.
USS dry boxes do not come with the INDX kit. 8 USS are approx $250, so no, unless you add them to your order.
Publié : 05/05/2026 8:15 pm
The dry boxes mount on the standard Core One puck, so you can just print more pucks and spool holders.
I don't see why I would want to spend all that money and mount 8 dry boxes. The only use I find for them is to print TPU and other moisture sensitive material. Or if you have only 8 rolls of filament, sure, keep them in the dry box. I'll have one or two of them mounted, the other mount points will be just regular spool holders.
Publié : 05/05/2026 8:57 pm
Randy Hearn
(@randy-hearn)
Membre
Spool mounting is fine. I have my own dryboxes really I  plan to use so assuming the mounts are the same should be good. But yes, I would rather have filament I use all the time in the boxes ready to go. But if doing a lot of printing like daily I can see where there is no need.
Posted by: @foxrun3d
Publié : 05/05/2026 10:00 pm
