Best spoolholderv alternatives sought?
docsascha
(@docsascha)
Doe anybody already have a dry box designed and working?
Opublikowany : 01/03/2026 11:31 pm
GreenPea
(@greenpea)
RE: Best spoolholderv alternatives sought?
You might want to check out this:
https://www.printables.com/model/1411246-inbxx-for-prusa-indx
Loving the learning curve!
Opublikowany : 03/03/2026 7:13 am
Has anyone already built an INBXX which sits below the printer? I would be reluctant to put the Core One onto such a tall and narrow base. Won't it shake like crazy?
I plan on buying a Creality SpacePi X4, to be placed on a shelf above the printer. Four filaments and two separate temperature zones should match my use cases nicely. I want to avoid the side-mounted spools, to retain the compact footprint of the Core One and the visibility of the print through the side panels.
Opublikowany : 03/03/2026 7:27 am
I am intrigued and might have to build one.
Opublikowany : 03/03/2026 11:21 am
