EasyPrint Update
Hello, new huge update is out! Here are the highlights:
Major Features
- Multi-Bed Slicing & Bulk Send
- 1-click to slice all beds in a project and send them to the printer
- Runs sequentially or in parallel depending on compute resources
- Negative Volumes ("Hole")
- Objects can now be set as "Hole" right next to the color settings. It calculates instantly before slicing and runs super fast also on mobile devices.
- "Print it faster!"
- Shows print time estimates for alternative, faster profiles after the initial slice—no manual re-slicing needed.
- Move to Bed
- Select objects and instantly move them to any existing or new bed.
UI & Enhancements
- EasyPrint Storage Smarts
- Personal model storage now shows file sizes and tracks links to projects (warns you if a file you're deleting is used in a project)
- Project Duplication
- Added project duplication feature
- Quick Renaming
- Input right in the header (with a save status indicator)
- UI updates
- Added app-wide tooltips, better filename-based auto-coloring, a search bar in the material selector, and fresh duotone context menus.
Bug Fixes
- Fixed the bug where objects stayed floating after deleting their bottom parts, plus general optimizations
For a more detailed description, see the public change log in the Printables article.
Kudos Ondřej Bartas (WebDev, Printables) Pavel Peroutka (WebDev, Printables) and @Filip Rafaj (Printables, DevOps)
Shane (AKA FromPrusa)
Veröffentlicht : 23/03/2026 6:04 am
