Chamber temperature for ASA high enough?
simmania
(@simmania)
Utenti
I ordered a Prusa Core One L printer. I'm waiting for the delivery. But now I have my doubts because I want to do a lot of ASA printing.
ASA needs a high chamber temperature like 70 degrees. But the Core One L only gets to 60 degrees.
Furthermore I ordered the filter kit. I'm afraid this extra filter with fan will make the maximum chamber temperature lower then 60 degrees.
In that case I will regret my choice for the Prusa Core One L.
Does anybody has some experience with this? And if this is a problem for ASA, is there a solution or work around?
Postato : 05/02/2026 3:27 pm
FabLabWag
(@fablabwag)
RE: Chamber temperature for ASA high enough?
No panic.
We have a plain Core One, so likely with even less effective chamber heating, but what we have printed in ASA (Prusament black) so far has turned out pretty good.
Postato : 06/02/2026 3:11 pm
_KaszpiR_
(@_kaszpir_)
I print ABS/ASA and it works, just need to close some holes to make it more air tight and you will be fine. I do not have the filtration, though.
See mu signature in Printables, Collections and there are some addons for the Core One L you may want to have.
Postato : 06/02/2026 5:57 pm
Yes, closing hole. Example taping over gaps in the frame. I also throw a blanket on the top to keep heat in. I can get around 58° which is good enough for most ASA.
Postato : 06/02/2026 6:37 pm
simmania
(@simmania)
Utenti
So when closing some holes it will be ok.
But this is a problem for a printer that includes the extra filter unit.
You need air to be able to enter the chamber because the filter unit will try to such air out the chamber.
So now I'm really concerned about this. A chamber temperature of 50-60 degrees using the filtration unit will then be difficult or impossible.
Postato : 06/02/2026 8:30 pm
Artur5
(@artur5)
50C is good enough for ASA, PA or PC. I`ve printed  quite big models in ASA with the chamber barely above 40C and no warping trouble. Whoever says that you "need" 70C is plain wrong. In fact, 70C is a sure recipe for shortening considerably the lifespan of consumer grade printers, not to speak of the safety risks involved when you print at this temperature, specially if you leave the printer unattended for many hours.
Postato : 13/02/2026 9:56 pm
1 persone hanno apprezzato
Posted by: @artur5
50° is not good enough for large PC parts. I went through 2 rolls of filament before I realized the chamber has to be closer to 60°. It's crucial to minimize the temperature difference between the print bed and the chamber. Problem is since the chamber is not actively heated, the print bed has to be higher than needed to keep the chamber warm. And the chamber has to be warmer as a consequence to minimize that temperature differential. If I had an actively heated chamber, then I can lower the bed temp to something sensible like 80° instead of the 115° it is now and run the chamber at 50°
Postato : 21/02/2026 8:02 pm
2 persone hanno apprezzato
simmania
(@simmania)
Utenti
I really hope they will release some separate chamber heating option. I do not like this indirect heating at all.
Postato : 21/02/2026 9:54 pm
DanShady
(@danshady)
This was my solution for the Core One L built off an existing mod for the Core One. Take a look, see if you think this could work for you:
https://www.printables.com/model/1620931-chamber-heater-for-core-one-l
Postato : 28/02/2026 8:43 pm
