PTFE/Wire Harness Support Arm
Ruebarb
(@ruebarb)
The PTFE/Wire Harness Support Arm is held by a post with a tension cap on both ends, didn't take long for the arm to droop, allowing the ptfe tube, which was installed wrong to hit, the top left corner of the fan housing, as the arm moved. I fixed the tube and then the wire harness was hitting. I replacing the post with a real M3 and lock nut solved the issue, keeping the arm in alignment.
Posted : 29/12/2025 9:10 pm
mnentwig
(@mnentwig)
RE: PTFE/Wire Harness Support Arm
That swing arm has even been in the spotlight as "Part of the Core One philosophy":
https://blog.prusa3d.com/prusa-core-one-january-update-its-just-around-the-corner_108917
Posted : 30/12/2025 12:02 am
Ruebarb
(@ruebarb)
Funny, the philosphy included a proper screw and nut, not the included garbage
Posted : 30/12/2025 12:43 am
mnentwig
(@mnentwig)
One thought: If the "L" is like standard Core one, the swing arm can be turned slightly on the back wall after loosening the screws that hold it. It's only a few degrees, but over the length of the swing arm it may be enough to stay clear of the fan.
Posted : 30/12/2025 9:14 am
Ruebarb
(@ruebarb)
Thanks, it is a 3 screw design, no rotation possible. After printing overnight, it is hitting again, but at least the arm is not drooping.
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/12/d0d078a4-hitting-fan.mp4
Posted : 30/12/2025 10:01 am
Ruebarb
(@ruebarb)
Prusa support was useless as usual and needed to get back to me. Doubt they'll have any real solutions to a clear design issue. This mod seems to be the answer for now.
https://www.printables.com/model/1524157-swingarm-extend-core-one-l
This post was modified 2 days ago by Ruebarb
Posted : 31/12/2025 2:50 am
