How to change Core One profile to standard (not HF) nozzle?
John
 John
(@john-4)
I've replaced the nozzle on my Core One with a standard hardened one.   The only profile I can find is for HF nozzle.   I've disabled HF in the printer settings but how do I do it in the slicer?   Right now I can't print as the gcode check finds the nozzle mismatch.    Help!
Napsal : 19/02/2026 4:40 pm
mnentwig
(@mnentwig)
Type "flow" into the search box (top of screen, halfway to the right). Among entries you'll see:
Size: High flow nozzle [154]
It points to printer - Extruder 1 - Size - High flow nozzle
Napsal : 19/02/2026 5:33 pm
John
 John
(@john-4)
RE: How to change Core One profile to standard (not HF) nozzle?
Cool, thank you 🙂
Napsal : 19/02/2026 5:55 pm
Posted by: @john-4
Open the configuration Assistant and select the non HF nozzle
Napsal : 20/02/2026 1:30 am
1 lidem se líbí
John
 John
(@john-4)
Cool, many thanks! 🙂
Napsal : 20/02/2026 3:37 pm
mnentwig
(@mnentwig)
True, there is a bit more behind changing the printer profile than just setting the "HF" flag.
Below a "diff" between the two configs:
< filament_infill_max_crossing_speed = 140
> filament_infill_max_crossing_speed = 200
87c87
< filament_max_volumetric_speed = 15
> filament_max_volumetric_speed = 26
94c94
< filament_ramming_parameters = "250 100 42.4194 42.4194 42.4194 42.4194 42.4194| 0.05 42.4387 0.45 42.4387 0.95 42.4387 1.45 42.4387 1.95 42.4387 2.45 42.4387 2.95 42.4387 3.45 42.4387 3.95 42.4387 4.45 42.4387 4.95 42.4387"
> filament_ramming_parameters = "250 100 42.4194 42.4194| 0.05 42.4387 0.45 42.4387 0.95 42.4387 1.45 42.4387 1.95 42.4387 2.45 42.4387 2.95 42.4387 3.45 42.4387 3.95 42.4387 4.45 42.4387 4.95 42.4387"
Napsal : 20/02/2026 4:15 pm
John
 John
(@john-4)
Thanks, I'll go check what my settings look like.
Napsal : 20/02/2026 6:19 pm
mnentwig
(@mnentwig)
There is nothing that looks dramatically important but they are not the same.
I don't bother with printer profiles in everyday use, change HF via the switch but that's less of a recommendation than a confession 🙂 Whatever, it usually prints as intended.
Napsal : 20/02/2026 7:14 pm
