How to change Core One profile to standard (not HF) nozzle?
I've replaced the nozzle on my Core One with a standard hardened one. The only profile I can find is for HF nozzle. I've disabled HF in the printer settings but how do I do it in the slicer? Right now I can't print as the gcode check finds the nozzle mismatch. Help!
Type "flow" into the search box (top of screen, halfway to the right). Among entries you'll see:
Size: High flow nozzle [154]
It points to printer - Extruder 1 - Size - High flow nozzle
RE: How to change Core One profile to standard (not HF) nozzle?
Cool, thank you 🙂
Open the configuration Assistant and select the non HF nozzle
Cool, many thanks! 🙂
True, there is a bit more behind changing the printer profile than just setting the "HF" flag.
Below a "diff" between the two configs:
< filament_infill_max_crossing_speed = 140 --- > filament_infill_max_crossing_speed = 200 87c87 < filament_max_volumetric_speed = 15 --- > filament_max_volumetric_speed = 26 94c94 < filament_ramming_parameters = "250 100 42.4194 42.4194 42.4194 42.4194 42.4194| 0.05 42.4387 0.45 42.4387 0.95 42.4387 1.45 42.4387 1.95 42.4387 2.45 42.4387 2.95 42.4387 3.45 42.4387 3.95 42.4387 4.45 42.4387 4.95 42.4387" --- > filament_ramming_parameters = "250 100 42.4194 42.4194| 0.05 42.4387 0.45 42.4387 0.95 42.4387 1.45 42.4387 1.95 42.4387 2.45 42.4387 2.95 42.4387 3.45 42.4387 3.95 42.4387 4.45 42.4387 4.95 42.4387"
Thanks, I'll go check what my settings look like.
There is nothing that looks dramatically important but they are not the same.
I don't bother with printer profiles in everyday use, change HF via the switch but that's less of a recommendation than a confession 🙂 Whatever, it usually prints as intended.
