How to achieve close to 60°C chamber temp?
[Solved] How to achieve close to 60°C chamber temp?
eggsa
(@eggsa)
The Prusa Core One L is marketed with up to 60°C. How can I achieve about 58-60°C for ideal ASA printing? There is basically no insulation of the enclosure and it looses too much heat. And the corners have open gaps.
Posted : 20/06/2026 3:59 am
eggsa
(@eggsa)
RE: How to achieve close to 60°C chamber temp?
I actually figured out a solution myself by covering the top with some insulating material and cranking up the temperature of the heat bed to 110°C. Given the constant heat radiation of the print bed it makes sense that the insulation of the enclosure has some limits.
Posted : 21/06/2026 3:20 pm
