Help: Filament sensor with it´s own life
Duck Druck
(@duck-druck)
Hi there,
if someone running the Core One L runs into similar issues.... How did you fix the "sometimes detecting - most of the time not detecting filament" issue? This is really annoying as the printer runs out of filament without noticing, dead running until the job finishes....and the printer doesn't provide any feedback or error messages at all
Any ideas?
Cheers,
Napsal : 27/01/2026 10:16 pm
_KaszpiR_
(@_kaszpir_)
RE: Help: Filament sensor with it´s own life
disassemble the filament sensors, recheck if the ball is properly moving inside?
https://help.prusa3d.com/article/nextruder-filament-sensor-core-one-core-one-l-mk4-s-mk3-9-s-xl_465702
or do you mean the side mounted filament sensor? https://help.prusa3d.com/guide/how-to-replace-the-side-filament-sensor-core-one-l_942491#962835
Napsal : 28/01/2026 11:48 am
1 lidem se líbí
