Display misaligned in injection molded casing
TvD
 TvD
(@tvd)
Utenti
I assembled the Prusa Core One+ and everything is okay, except that the display is mechanically shifted about 1 character to the left.
On the right side of the display the black stripe (unused display section) is visible and on the left side about 1 character is behind the injection LCD cover.
The rotaty button is in the center of is't hole in the front, so it seems my mechanical mounting is done okay.
How can I solve this in a neat way, not by filing the bevel of the enclosure.
Postato : 10/03/2026 1:08 pm
Same Old Shane
(@same-old-shane)
Utenti Admin
RE: Display misaligned in injection molded casing
I would double check the assembly to make sure everything is fine and then reach out to support. If it's a defective part, then it should be replaced.
They will also ask for your order / serial number of the printer so they can also keep track and see if its a repeated issue and can then take the next needed steps.
Shane (AKA FromPrusa)
Postato : 10/03/2026 4:17 pm
1 persone hanno apprezzato
