Belt tension?
does anyone know what the belt tension is supposed to be on the core one L? Mine seems a bit loose from the factory (especially compared with my core one) but it seems to print ok. I wanted to double check it.
when I stein it’s like 60hz but prusa recommends over 90s for the original core one. And I can’t seem to find any details on the help articles
Posted : 11/11/2025 10:15 pm
RE: Belt tension?
Use the belt tuner in the firmware, that should let you know if it needs tightening (and it also shows the proper values, looks like between 85 and 95 Hz).
Posted : 13/11/2025 12:59 am
