Size of filament spool compartment
Jeroen
(@jeroen-3)
I like using 5kg spools, and I wonder if these will fit. How big is the spool compartment on the side of the printer?
Best Answer by alphasigma:
https://www.printables.com/model/1520379-prusa-core-one-l-full-cad-assembly
A 5 kg spool will not fit within the "side compartment" and due its weight you need an appropriate spool holder with support on both sides...
Posted : 26/02/2026 7:15 am
alphasigma
(@alphasigma)
RE: Size of filament spool compartment
Core One L
Posted : 26/02/2026 9:07 am
Jeroen
(@jeroen-3)
Thanks! Indeed, using the step-file I could confirm the 5kg spools I use do not physically fit in the spool holder compartment, even apart from the weight concern. So I'll just have to live with 1 or 2 kg spools.
Posted : 26/02/2026 9:52 am
alphasigma
(@alphasigma)
Posted by: @jeroen-3
Why only with 1, 2 kg spools? Why not designing a holder for 5 kg spools placed next to the printer...or take an already designed one...?
https://www.printables.com/search/models?q=5+kg+spool
Core One L
Posted : 26/02/2026 12:37 pm
Jeroen
(@jeroen-3)
Posted by: @alphasigma
Space reasons. I have a spool holder that fits my 5kg spools ( https://www.printables.com/model/293431-spool-holder-holding-up-to-large-3kg-spools ), but I don't have room for a Core One L and a spool holder side-by-side.
This post was modified 2 days ago by Jeroen
Posted : 26/02/2026 12:57 pm
alphasigma
(@alphasigma)
This https://www.printables.com/model/1361348-2-kg-spool-support-for-core-one remixed for a 5 kg spool still too wide...? Sorry, never had a spool bigger than 1 kg in my hands...what are the dimensions of a 5 kg spool? Thx in advance!
Core One L
Posted : 26/02/2026 2:09 pm
_KaszpiR_
(@_kaszpir_)
Personally I have a similar issue - a bit of lack of space on the sides, so I used LACK to stock things under the print. In the future will move with the spools to be placed above it, probably. Unfortunately those things get bigger and bigger....
Posted : 27/02/2026 7:46 am
