Chamber heating slowed down by the... camera
_KaszpiR_
(@_kaszpir_)
First print with ABS, waiting for the chamber heat up was noticeably longer than expected - closing all holes, vent on the back, sealing top panel with something heavy so it is pressed to the enclosure and closed the top vent grill.
Well, apparently you cannot fully close the top vent grill because the corner of the moving part is hitting the case of the camera in the corner - see pictures.
Should be fixable with a new camera design or few mm distance from the top, so I suspect 6x2 mm magnets ( typical gridfinity) could work in here.
Publié : 26/01/2026 8:24 am
Ruebarb
(@ruebarb)
RE: Chamber heating slowed down by the... camera
Review your camera install, mine clears with no isses.
Core One L MMU3, MK3S
Publié : 26/01/2026 1:34 pm
1 personnes ont aimé
_KaszpiR_
(@_kaszpir_)
Any camera reseatings were insufficient, I had to cut down one corner of the camera to fix it.
Publié : 26/01/2026 8:37 pm
Alienbliep
(@alienbliep)
Same issue here. Pretty stupid. I was questioning my sanity
Now what to grind down? The grille or the camera...
man ooh boy.
Ce message a été modifié il y a 3 months par Alienbliep
Publié : 10/02/2026 4:33 pm
_KaszpiR_
(@_kaszpir_)
You can reprint camrea enclosure if you fail, so use filer to remove about 2mm of camera enclosure.
Publié : 10/02/2026 9:10 pm
Alienbliep
(@alienbliep)
I chose to grind the grille down.
I have no pccf for camera reprint.
In the future with index i dont need the grille anymore i think
Publié : 10/02/2026 9:14 pm
_KaszpiR_
(@_kaszpir_)
You don't need pccf for camera enclosure...
Also cutting the panel may be more prone to cracks.
Publié : 10/02/2026 10:42 pm
Kachidoki
(@kachidoki)
Same here, is there a remix somewhere with a proper cutout? I only found the original design here but no such remix.
Publié : 20/03/2026 2:40 pm
_KaszpiR_
(@_kaszpir_)
this might help https://www.printables.com/model/1375366-core-one-buddy3d-camera-lid-remixed-to-improve-vie
I used it already
Publié : 21/03/2026 1:48 pm
Kachidoki
(@kachidoki)
Thank you, I've just designed my own remix released on Printables.
Publié : 21/03/2026 2:44 pm
Kachidoki
(@kachidoki)
Made a short vid to clearly show the collision.
Publié : 22/03/2026 1:50 pm
