Brass Nozzle Cleaning.
Mac-N4MCC
(@mac-n4mcc)
I am noob.  Is there anything I can soak a brass nozzle in that will EAT PLA or PETG out of it and off of it?  I have a lot of build up and am tired of buying more nozzles.
Extra HAM (and eggs some say) Radio - N4MCC
Postato : 07/12/2025 9:29 pm
1 persone hanno apprezzato
jan.d.slay
(@jan-d-slay)
RE: Brass Nozzle Cleaning.
To clean the nozzles, simply leave them installed in the extruder and heat them to approximately 230 degrees.
You can then use a wire brush to remove the soft filament, leaving them looking like new.
There are a few reasons why excessive filament may accumulate on the nozzle.-
  • The flow rate is too high
  • The filament is not dry
  • The retraction speed or retraction distance is too small/low
Postato : 08/12/2025 8:17 am
iftibashir
(@iftibashir)
Echo the above. I use the same nozzle for years (just PLA) and it looks completely clean even though I've never touched it! I do check and use needle nose pliers to pick off any plastic immediately after any print though...... lol, but saying that, even that's rare. I do find PETG more 'messy' to work with though - but then again, I never really dry filament.....
Postato : 08/12/2025 9:27 am
2 persone hanno apprezzato
Ruebarb
(@ruebarb)
While hot, as mentioned above. Been using round tip tweezers for years, grab any ozze before/after the print and anything left on the nozzle. Don't bother with a brass brush.
KNIPEX - 92 64 43 Tools - Precision Tweezers, Chrome (926443)
https://www.amazon.com/KNIPEX-92-64-43-Precision/dp/B005EXOULI/ref=sr_1_9?crid=2YJPX87OH8M53&dib=eyJ2IjoiMSJ9.0kjijJEeSE89t9o1ptQVFoOs2jyiHHEQwh-A5DELnRTsFMRjjRpSPIPAJvc25N0JI31wESXc2AS7DX_wXBcBDrVglgbqM0t00QQ7V0ZVIHsCKbzJIk79yL8mAOhyKcda1izXWAsqOC10xQyVfgxmDus7V5QMrVO9VRgHA7sZgAz1DLWBHN0m8e3DptbYppmWEgRsdkpuoB6lSgtcMe4hWlgHO7WhzsDcqV5uoDtbD6He4o3mirr_o87cnkid861p0Kd9C_YjFY9XPB8dqm_w78hpxNcAOYruWtpwL2wRhf8.eAcGiRVgfLe3-9fVvHtb1zrIgOGYwgMapUJMF8QLhdo&dib_tag=se&keywords=knipex+tweezers&qid=1765206330&sprefix=knipex+tweezers%2Caps%2C151&sr=8-9
Core One L MMU3, MK3S
Postato : 08/12/2025 3:09 pm
NickAtNight
(@nickatnight)
So we heat to 230z… then what?
Postato : 10/12/2025 4:41 pm
My suggestion is to go on to Printables, find a Core One nozzle wiper (there are a ton of these, just pick your favorite) and use it to automatically scrub the nozzle between printers.
This is one I created to specifically to be out of the way and also work with BIQU Cryogrip sheets: Core One Universal Nozzle Wiper Use the right-hand version if you have the Core One+ automatic vent upgrade.
Why Prusa doesn't have this as standard (everyone else does) is beyond me...
Postato : 10/12/2025 6:05 pm
mnentwig
(@mnentwig)
Regarding "out of it": Have you checked "Cold pull" procedure? It's easy to find a better explanation than I could write up here in a few lines so I won't try (in a nutshell, the trick is that moderately hot PLA gets extremely sticky). Surprisingly efficient.
Postato : 10/12/2025 7:06 pm
Ruebarb
(@ruebarb)
Remove the material stuck to the nozzle
Posted by: @nickatnight
Postato : 10/12/2025 7:55 pm
