Wipe tower causes layer shift
mikael
(@mikael)
I am printing an object in PLA with two filament changes, on the Wipe tower the first filament change deposits a rather large blob (2.3 mm high),  then at the second filament change the nozzle runs over the blob during the wipe process, and this often causes a layer shift (app. 2 out of three time).
What slicer settings can I change to avoid that the nozzle runs over the blob? I am currently use the default Wipe tower settings.
Prusa Core One FW 6.3.0
Prusa Slicer 2.9.1
Opublikowany : 28/03/2025 5:16 pm
1 ludzie polubili
Plastic Golem
(@plastic-golem)
RE: Wipe tower causes layer shift
Posted by: @mikael
Prusa Slicer 2.9.1
Did you ever work this out? I’m having the exact same issues on my MK4S.
I’m really regretting buying their MMU3 as it’s turned a very reliable machine into something which cannot even complete prints correctly.
Opublikowany : 24/07/2025 10:08 pm
mikael
(@mikael)
I don’t have solution, but my workaround is place the wipetower in front of the plate and then remove the wipe tower after each filament change, that works for me as I only need two-three color changes at the first 3-4 layers.
i don’t have an MMU for my CoreOne so the filament change is done manually, so it is easy for me to remove the wipetower in the process.
A more permanent solution would be to place the blob at different places next to the wipetower when color changes are needed in the first 3-4 layers, but this would have to be a programmatic change to the slicer that I am not capable of.
I hope someone from the Prusa team reads this and can implement a fix.
Opublikowany : 25/07/2025 6:24 am
Hi Mikael,
Prusa developers rarely look here,
you would be better going to the prusa slicer Git Hub page, searching to see if a similar idea has already been raised, then either adding to that idea or proposing your own idea
regards  Joan
Opublikowany : 25/07/2025 9:49 am
