Support Material hard to remove
docsascha
(@docsascha)
Dear all,
Just started with some 3D Models of figures needing quite much support it's hard to remove them after printing. Organic supports had better results but still a pain to remove.
Used Buddy PLA and given setting on PRUSA Slicer with my C1
Some ideas for better results
BW
Sascha
Respondido : 08/10/2025 3:06 pm
You can adjust the contact distance between the supports and the object (Print settings > Support material > Top contact Z distance). For fine tuning, values which are not multiples of the layer thickness are also supported -- the slicer will generate GCode that goes to a separate Z position for the supports.
Or you can try reducing the extrusion temperature a bit, to make the filament "less sticky". Don't overdo it of course, since the adhesion between layers within the print is also affected.
Edit: Oh, and you can try a less dense "Interface pattern spacing" (also in the Support settings), and maybe experiment with the Interface pattern itself too.
Respondido : 08/10/2025 3:16 pm
1 les gusta
docsascha
(@docsascha)
RE: Support Material hard to remove
Thank you Jürgen
Respondido : 08/10/2025 3:28 pm
