Rough outer wall only in one spot
Trilobyte3D
(@trilobyte3d)
I've been running into this problem, and none of the changes I've made are working. It was originally only happening on one side, but that changed when I shrunk the model, and it happens in a different side on the same layers. Things I've tried so far...
-Tightened belts
-Added an additional outer wall n=3
-Reduced size of print 1% because it was at the limit of the machine
-Changed infill % from 10 to 15
-Tried Speed profile
Machine specs
- Prusa Core One + Assembled
- PLA eSun
- Running the default Balanced profile with Gyroid infill
.2 layer height on the stock .4 nozzle.
Postato : 07/06/2026 1:28 am
That looks like a warping pattern - please show us the underside of a failed print.
Postato : 07/06/2026 11:53 pm
Trilobyte3D
(@trilobyte3d)
RE: Rough outer wall only in one spot
Smooth and flat?
Postato : 08/06/2026 11:12 pm
Not a helpful image 'though I see you have a curved bottom corner - a bad design choice for 3D printing, converting that to a chamfer would give a neater print.
It might be something as simple as a highly optimised file which has broken on shrinking.
- We'd better take a look at the geometry:  save your project as a .3mf file
Files > Save Project as
Postato : 09/06/2026 9:25 am
