Prusament PP Glass Fiber Filament and Cryogrip Biluild Plate?
docsascha
(@docsascha)
Cryogrip build plate is one fine addition to my X1.
Now I want to print some laboratory stuff using
Now I want to print some laboratory stuff using Prusament PP Glass Fiber Filament.
Has anybody experience printing PP-GF onto the Cryogrip
Filament.
Has anybody experience printing PP-GF onto the Biqu Cryogrip build plate or should I order the one suggested by prusa?
Best Answer by hyiger:
Polypropylene only sticks to itself. You cannot use a standard build plate without preparing it
There are four choices (I’m aware of):
  1. you can get a dedicated PP plate (Prusa sells one)
  2. get a standard sheet (I’ve used a cheap textured plate) and cover the print area with polypropylene packing tape
  3. Yousu (a filament manufacturer) sells adhesive PP sheets that you can stick to the plate
  4. Magigoo PP should (in theory) work on a standard plate however I haven’t tried that
Opublikowany : 27/01/2026 7:45 pm
RE: Prusament PP Glass Fiber Filament and Cryogrip Biluild Plate?
Opublikowany : 28/01/2026 12:12 pm
1 ludzie polubili
docsascha
(@docsascha)
Thank you for the answer!
Opublikowany : 28/01/2026 12:16 pm
