Problem with "inside" of print
I am printing part for gears/differential for an RC car in Prusament PETG. I use default settings profile i Prisaslicer with slight slower first layer speed.
The surface is fine, but why do the inside/side facing down of housing become threaded an rough? Parts and bearing will not fit this way.
What do I do wrong and how can I fix it?
STL file:
Questa discussione è stata modificata 3 months fa da aerobat
Postato : 02/02/2026 9:56 am
Can you save your project as a 3MF, zip it and attach? Hard to tell, but you probably just need to add supports in the right places.
Postato : 02/02/2026 9:34 pm
1 persone hanno apprezzato
RE: Problem with "inside" of print
Postato : 02/02/2026 11:22 pm
Topic starter
answered:
Thanks for your answers.
I realize now that it is my lack of understanding that is the main problem.
The problem areas is "printing in the air". I fixed by using organic support and also turned the larger part upside down.
Postato : 03/02/2026 8:29 am
