print with pla woodfilament small overhang problem
dutch3dprints
(@dutch3dprints)
Hi, I made this design and printed it on my core one + using the Prusa High Flow ObXidian™ - 0.6 mm nozzle. 20% infill, 0,32 mm Balanced. Bambulab PLA wood, using the Prusa woodfill profile. Overall it came out very nice. But at some points it is not so nice (picture). I printed it sideways than it has some minor overhang. At the top. Can I get this better, without using supports? My experience using supports is not good, so I try not to use them if not needed. What would be your advise. here? If I change the print direction, the overhang will even be larger so might not be the best solution.
Napsal : 18/05/2026 10:51 am
If it's your design consider replacing the curves with 45° chamfers - design for the process.
Napsal : 18/05/2026 3:33 pm
