print looked perfect until I pulled it off build plate
Odyssey ventures
(@odyssey-ventures)
What do I need to do different?
The rest of the print looks perfect. Just seemingly under extrusion after the seam. It is overture PETG. You can see where I changed rolls...first roll has been open for days and the second roll was vacuum sealed until just before loading onto printer.
Print profile is a native Prusaslicer one.
     .20 SPEED
     Generic PETG
modified for 5% gyroid infill
Napsal : 25/05/2025 3:49 pm
Raaz
 Raaz
(@raaz-2)
RE: print looked perfect until I pulled it off build plate
Please save your Slicer project, then zip it and upload it.
Might be speed related or another setting. Or wet filament that doesn't like the acceleration.
I had freshly delivered rolls that were pretty wet. Putting it into my dryer made the humidity go up to 60%, instead of quickly dropping down to 10% and staying there (like with really dried filament).
Napsal : 25/05/2025 5:05 pm
Odyssey ventures
(@odyssey-ventures)
ppv4
My first time doing this...hope it works.
I live in the desert in Idaho and usually don't have to worry about humidity but perhaps the moisture is being shipped in.
Napsal : 25/05/2025 8:22 pm
Biomech
(@biomech)
Probably Overture PETG issue (many users complains about it's poor quality recently). Try printing if with another brand.
Napsal : 25/05/2025 8:39 pm
Odyssey ventures
(@odyssey-ventures)
Oh. I've been printing their pla and had good luck.
It is printing again now but with some Zyltech PETG. I'll let you know.
Napsal : 25/05/2025 11:00 pm
Odyssey ventures
(@odyssey-ventures)
Posted by: @raaz-2
What dryer do you use?
Napsal : 25/05/2025 11:12 pm
Odyssey ventures
(@odyssey-ventures)
Ok it is apparently doing the same thing on other filament. I'll slow it down and try again.
Napsal : 25/05/2025 11:47 pm
Raaz
 Raaz
(@raaz-2)
Posted by: @odyssey-ventures
Posted by: @raaz-2
Just the little eSun Lite box, nothing special.
To check the humidity and temperature, I simply put two of these cheap temperature+humidity sensors into the center of the spool. Bought 20 of them for DIY-cereal-dryboxes.
If you want us to really check your project, please save + zip it and upload it here. That way, we can check speeds, accelerations, flow etc.
Napsal : 26/05/2025 3:20 pm
Odyssey ventures
(@odyssey-ventures)
I thought that's what I did here. Is this file you need different than this?
ppv4
Napsal : 26/05/2025 7:37 pm
Odyssey ventures
(@odyssey-ventures)
So I changed the settings to. 20 structural and it worked a lot better but still leaving about 1/2" looking rough.
Napsal : 26/05/2025 7:57 pm
carlmmii
(@carlmmii)
Looks like it's a flow instability after retractions. It's likely something you can compensate for with tuning down your retraction speed/acceleration/jerk.
Retraction speed would be in your filament settings. Acceleration/jerk will be in the printer settings.
It could also be that you just need to adjust the pressure advance for that filament. There's plenty of methods to do this, but considering you've already got a cylindrical model, you can add custom g-code every few mm to change the PA value and see what effect you get (go crazy at first like .1 increments, then dial in -- it can be tricky at first to see any difference if you're only adjusting by .01).
Another thought (purely speculative, haven't done much testing myself on this matter yet, since I don't have anything as pronounced as what you're dealing with), but are you using a CHT or HF nozzle? I'm wondering if the smaller channels may be contributing to the flow instability.
This post was modified před 1 year by carlmmii
Napsal : 31/05/2025 12:58 am
Odyssey ventures
(@odyssey-ventures)
Posted by: @carlmmii
Thank you for the information and ideas Carl. I will play with those settings.
I am using the CHT nozzle that comes in the Core One. I just bought some standard .5 Prusa brass nozzles that I want to install and try with as well.
Napsal : 31/05/2025 3:24 am
What is this part?  Does it need to be so flimsy?
You have only two perimeters on a tapering part, the whole wall structure is left open at the top ...
As a result the slightest flaw from what looks like imperfectly dried filament is enough to disrupt the print; even one more perimeter would give it a chance to close the structure so that the next layer would have something to support its perimeters.
Try this with an unmodified print preset - or even convert it to vase mode if it must be ultra-light.
Napsal : 31/05/2025 4:45 am
Odyssey ventures
(@odyssey-ventures)
Posted by: @diem
Haha There are currently two printing in vase mode and they are working great.
They are my version of a water wall for protecting plants from freezing, so I really wanted to be able to fill them with water.....Hence the gyroid infill.
I did try three perimeters but it wasn't much better.
Napsal : 31/05/2025 5:21 am
Odyssey ventures
(@odyssey-ventures)
Posted by: @diem
Also the roll was dried for seven hours @ 65C but it made little difference.
Napsal : 31/05/2025 5:22 am
