PETG and ObXidian 0.6 HF nozzle
reinvented.tech
(@reinvented-tech)
The default volumetric speed in Prusa Slicer for PETG and 0.6 HF nozzle is 31 mm3/s (both for Prusament and generic PETG). What is maximum value non resulting in risk of clogging? What is your experience?
Napsal : 26/04/2025 10:14 am
LarGriff
(@largriff)
RE: PETG and ObXidian 0.6 HF nozzle
Well, it’s 31 mm3/s.  That’s why it’s called MAX Volumetric Speed.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Napsal : 26/04/2025 12:42 pm
Biomech
(@biomech)
If you want to know the limit, you have to run volumetric speed test for your filament. Values in slicer filament profiles are more likely safe than maximum.
Napsal : 26/04/2025 8:04 pm
Artur5
(@artur5)
31mm3/s is quite high, for the hotend of this printer. PLA will be maybe OK. but PETG is often a nasty customer, specially when it's a bit wet. As a safe rule, I wouldn' t go higher than 25mm3/s or so (.. good luck fixing a clog in a HF nozzle ). Anyway, the possible trouble with the volumetric speed being too high. would be rather underextrusion than clogging.
Napsal : 27/04/2025 11:13 am
Biomech
(@biomech)
Prusament PLA has 24 mm3/s (generic PLA 22 mm3/s) in slicer profile, but Core One PLA sample prints goes up to 34 mm3/s (with regular PLA). The Nextruder with high flow nozzles is very powerful. E3D documentation states that 0.6mm HF ObXidian should run PETG at 240°C at rate 36 mm3/s. With bumping a temperature a bit it should go even more. Also high flow filaments may give it a significant boost. I have not tried to find a limit yet, but I would expect it to be more than 40 mm3/s (depending on filament used).
Napsal : 28/04/2025 1:41 pm
