Matte black PETG -- any recommendations?
I need to print some button (switch) caps for a re-creation of a vintage piece of hardware: Matte black cylinders with inlaid lettering on the front surface. I don't want to use PLA since these will be handled a lot, and the back-end of the cap needs to be reasonably robust -- it guides the plunger movement and has some thickness constraints .
So I am looking for matte black PETG, or a "better" matte filament. I can't use filaments with added fibers since the caps need to be printed with a 0.25 mm nozzle (or 0.2 mm with INDX going forward), to get a good definition of the inlaid letters.
The choice of matte PETG is quite limited, and the reviews (where available) are very mixed. Does anyone have a proven recommendation? Many thanks!
Napsal : 23/02/2026 8:59 am
PLA is actually the better choice for detail. PETG tends to get stringy at that resolution. You could give this a try: Pro PCTG, Matte Black I have a roll of it in red (haven't tried any other colors yet). Once it's dialed-in, it prints well and gives better detail than PETG.
Napsal : 23/02/2026 2:37 pm
1 lidem se líbí
RE: Matte black PETG -- any recommendations?
Thanks! I hope to get away with PETG regarding the detail, since it's really only the bottom layer (front face of the buttons) which is critical. And I would like to get the increased tensile strength over PLA, to get robust guides for the plungers. I have never used PCTG -- will give it a try!
Napsal : 23/02/2026 2:43 pm
The only reason I haven't used this as my goto filament is it's more expensive than generic PETG (but then the same as Prusament). It's great for outdoor stuff since it's easier to print and warps a lot less than ASA. You can also leave it out like PLA and not have to pop it in the dryer as often as PETG.
Napsal : 23/02/2026 2:48 pm
I did manage to pick up a roll of PCTG Matte Black  the other day. I've dialed it in for a Diamondback 0.4mm and doing the Obxidian 0.4HF next then will switch over to 0.6. It does print better than PETG, just more expensive (about the same as Prusament though).
Napsal : 03/03/2026 2:24 am
1 lidem se líbí
Mchad65
(@mchad65)
I started using 3d-fuel PCTG a couple of months ago and found the same results. Easy to print, great detail and I find much less stringing. I haven’t had any opportunity to test strength, but they *say* it’s stronger than PETG. I have an Amazon subscription for some which brings it down to $33/kg which is still about $15 more than the Polymaker PETG which is my go to of that material, so it’s not my everyday filament.
Napsal : 04/03/2026 12:33 pm
1 lidem se líbí
Cédric
(@cedric)
If you dont mind spending the swedish manufacturer add:north pro matte series is incredible. I use the HT-Pla pro matte for parts that will be seen and handled that needs to look perfect, where i I dont want fibre materials, probably the nicest looking non CF material ive used, they have PETG aswell.
Napsal : 06/03/2026 8:23 am
1 lidem se líbí
GertL
(@gertl)
I can just second this.
Addnorth filament is very good, only using these.
Sweden so it makes the delivery cost ok.
https://addnorth.com/
Posted by: @cedric
Gert
Napsal : 06/03/2026 9:34 am
Cédric
(@cedric)
Posted by: @gertl
Posted by: @cedric
They do have good dicounts once in a while, for example black friday etc, for stocking up 🙂
Napsal : 06/03/2026 9:56 am
