How to print Prusament TPU 95A
SpaceOctopus
(@spaceoctopus)
Mitglied
Hi!
Could someone point me to an explanation for how to print Prusament TPU 95A on the CoreOne+ ?
According to Prusa's blog post it should just work. To quote: "Easy printability: No idler tweaking and flawless printing with the Nextruder!", so I assume I am doing something wrong.
I cannot get it past the filament sensor at the extruder without removing the PTFE tube, which is a hassle and also probably not great for the parts to do that a lot.
When I remove the end of the PTFE tube from the extruder, I can feed the filament through the sensor by hand.
However, it still won't print. The Nextruder just chewed up the end of the filament, requiring manual intervention to unload it.
I have read other posts on here that are suggesting various tweaks to the printer. I am at a loss for what to actually do.
Is it a better idea to just shelve the filament until the INDX upgrade comes out and hope that it works better with that?
Thank you!
Veröffentlicht : 20/01/2026 9:15 pm
JustMe3D
(@justme3d)
RE: How to print Prusament TPU 95A
Maybe that thread is of help to you?
https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/core-one-and-soft-tpu/
Veröffentlicht : 20/01/2026 11:25 pm
Some flexible filaments are stickier/grippier than others and build up friction inside the PTFE tubes.  In that case it pays to mount the spool above the printer and bypass the delivery tubes by feeding it directly to the toolhead - yes you are uncoupling the end of the PTFE from the extruder but that's why it's mounted that way.
And the no-idler-tweaking is sort of true;  You will probably need to tweak the setting the first time you use TPU but then that setting can be left in place for (nearly) all other filaments.   Keep careful count of the idler screw turns - you may be only a fraction of a turn off and it's easy to overshoot so you need to know how far to undo if you need to go back.
The thread linked to by @justme3d is for much softer filament than you are trying so you shouldn't need all of it.
And the big secret for all flexible filaments - print slowly.
Veröffentlicht : 20/01/2026 11:28 pm
SpaceOctopus
(@spaceoctopus)
Mitglied
That thread gave me the idea to unscrew the PTFE tube, which at least got me a little further I guess?
I did not feel any noticeable friction from pushing the filament through the tube. That's of course not exactly scientific, but it felt really no different from pushing PLA filament through.
The first issue I encounter is that the physical resistance of the filament sensor in the extruder is too strong. I should probably have made that more clear in my first post. I simply can't build enough force through the filament to push it past the sensor while it's going through the tube.
So far I just assumed that using the profile Prusa provides in Prusa Slicer would do the trick. Assuming that I can ever get the filament to load, should I tweak the settings further?
Veröffentlicht : 21/01/2026 12:02 am
And dry the heck out of the filament.
Veröffentlicht : 21/01/2026 12:12 am
There's at least one Nextruder modification on Printables that replaces the spring with a magnet.
https://www.printables.com/model/1263406-nextruder-filament-sensor-magnet-mod
I was contemplating installing it but I used that same guy's spring-to-magnet mod for the XL side sensor and didn't see any meaningful change in force required to get the filament through.
Veröffentlicht : 21/01/2026 12:28 am
Veröffentlicht : 21/01/2026 12:32 am
The extruder isn't pushing, it's pulling; if it grips at bends the pull causes the grip/friction to increase.
Prusa's presets are usually good so start there but the first thing to try with all flexible filaments if problems occur is - slow down.
And @foxrun3d is right; dry your filament.
Veröffentlicht : 21/01/2026 4:25 am
Artur5
(@artur5)
TPU is not easy to dry. Many driers out there reach only around 60C/140F and this isn't hot enough for TPU. In spite of what Sunlu, PrintDry or even Prusa claim in their instructions, most TPU filaments need 80C/176F to be dried correctly. Otherwise you're wasting time and electrical energy.
Diese r Beitrag wurde geändert Vor 5 months von Artur5
Veröffentlicht : 22/01/2026 4:26 pm
mnentwig
(@mnentwig)
Thanks for that. I should read more Prusa blogs when I feel depressed.
Meanwhile, I remove the PTFE tube from the printhead and just feed it in through the open top cover (needs no chamber temperature). Works well enough.
Note to self, just remember to re-enable the side filament sensor even though I never use it or the MMU will fail with an obscure error... Logic v2.0.
Veröffentlicht : 22/01/2026 7:49 pm
That one got me too!
Veröffentlicht : 22/01/2026 9:16 pm
SpaceOctopus
(@spaceoctopus)
Mitglied
So, time for an update. I got it to work. Basically just now. Not the problem I thought it was.
Turns out the problem was that my side filament sensor wasn't working. It was permanently stuck on "inserted".
I randomly found that out while doing some unrelated troubleshooting. Turns out that in order for the sensor lever to move freely I have to unscrew the housing far enough to leave about a 1mm gap between the halves of the shell.
With the side sensor not engaging, the nextruder would only start the loading routine when filament reached the sensor in the nextruder. This worked for PLA, PETG, and ASA, but I could not get the TPU far enough in.
With the sensor fixed, the loading works correctly and it prints perfectly fine with the default Prusa profile.
I have no idea how the sensor passed calibration, maybe the lever was just loose enough in just the right place to work for a bit. I remember testing this.
Veröffentlicht : 24/02/2026 7:29 pm
Conrad
(@conrad-2)
Glad you sorted it! I'll add one more thing. Somewhere I read that you should cut an angle on the end of the filament and I routinely do this for all filaments. Seems to help with feeding through the sensors and into the Nextruder.
Veröffentlicht : 25/02/2026 5:47 pm
