How do I print a Bambustudio file on Core One + with MMU3
stevo1957
(@stevo1957)
I'm wanting to print this:
https://makerworld.com/en/models/1921857-hal-rotterdam-nieuw-statendam1-500-cruise-ship?from=search#profileId-2223857
I can't work out how to create a preset for the Core One + in Bambustudio so have tried exports of the 3MF and STL files to use in PrusaSlicer, but the plates import the STL's all over the place and the multimaterial paint colours do not import properly.
Is there a way of using the CoreOne + with MMU3 for this file?
I've read that Orca slicer will do it but get lost trying to configure the Core One for OrcaSlicer and when I did try, had gcode errors come up as well.
Appreciate any help.
Opublikowany : 16/05/2026 10:24 pm
It shouldn't be too difficult.  Mostly a matter of rearranging STL's but if all the colour work is done by painting instead of in CAD you might have to recolour some of it.
Unfortunately Bambu's Makerworld license means that no-one here can help you - if one of us comes up with a fix we are forbidden to upload it by the license - although it appears to be OK with Bambu to first publish it here and then copy it to Makerworld they expressly forbid going the other way - and that seems to apply even if the original is deleted from Makerworld first.
Opublikowany : 16/05/2026 11:03 pm
2 ludzie polubili
