Filament type PCTG missing in menu + Firmware bug
OyvindW
(@oyvindw)
Miembro
Trying out Fiberlogy PCTG filament. The PCTG filament are in PrusaSlicer but not in Prusa Core One filament menu. Please add PCTG to Prusa Core One menu.
Firmware bug: The gcode has PCTG filament type and the Prusa Core One filament type is set to PETG (missing PCTG). An error occured saying that the door is open.
Printer hang. After restart the only solution to print the gcode with PCTG is to disable the door sensor.
Firmware version: 6.3.2
(Yes, I know about the Custom filament setting).
Este debate ha sido modificado el hace 4 weeks por OyvindW
Respondido : 18/04/2025 1:02 pm
This is a user to user forum.   All bug reports and feature requests need to be made at the appropriate Prusa github repository.
For Prusa Slicer that is here https://github.com/prusa3d/PrusaSlicer/issues
For the MK4/Core One that uses the Buddy board then that is here https://github.com/prusa3d/Prusa-Firmware-Buddy/issues
Please follow the guidelines for opening new issues.  Also please search using as many relevant keywords as you can to avoid duplicates.
However for Prusa Slicer you do realise you can add your own filament types ?  While the field in Filaments>Advanced>Filament Type is a  dropdown you can type in whatever you want in there.
That along with prusa already allowing you to configure a custom one on the Buddy firmware would seem to fulfil your stated requirement.
Pretty Sure I already saw this request several times on the buddy repo and prusa adding the custom type is their response to that so I doubt you will get a specific one added.  https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/3915#issuecomment-2343549191
Respondido : 18/04/2025 1:53 pm
