Extra Long Bridges
Samael
(@samael)
Extra Long Bridges
So i am trying and failing to print these great looking models from Pozsar in Makerworld.
https://makerworld.com/en/models/1230224-transcend?from=search#profileId-1248860
Using e-Sun PLA with various speeds and settings i cant get the bridges to anchor correctly, fail rate is >50%
Fiddled with accelerations and speeds overall and on the overhangs especially but didn't make much difference...
Higher filament temps didn't do much either, didn't try lowering them significantly yet though.
Has some one tried those models? Any special tricks and tips?
Veröffentlicht : 23/12/2025 12:01 pm
RE: Extra Long Bridges
Posted by: @samael
Can you ZIP your 3mf project file and attach it? Please don't attach a RAR. I don't want to have install a utility to unpack it.
Veröffentlicht : 23/12/2025 3:12 pm
Samael
(@samael)
Hi, sure, i am attaching it, thx.
Veröffentlicht : 23/12/2025 3:24 pm
Ooph. This will be difficult to print.
I would suggest start with drying the filament first. Any moisture in the filament for a print like this will result in failure.
Do you have a filament dryer? If not place the spool on the print bed set for 50C cover it with a box and leave it there for 6-8 hrs.
If you don't have a dryer, I highly recommend you purchase one unless you live in a desert.
Veröffentlicht : 23/12/2025 3:45 pm
Samael
(@samael)
Hehe, i am not giving up, yet!
I do have a dryer but didn't dry the spool as it sits in a room with a constant 40% humidity, and since the spool is about 1 month old, i guessed it would be fine.
Will give it a shot though, nothing to loose!
Veröffentlicht : 23/12/2025 4:18 pm
Posted by: @samael
Nope. It's not fine. Try drying it first.
Veröffentlicht : 23/12/2025 4:35 pm
