ejects filament on 'continue' while loading filament
GreenPea
(@greenpea)
Ok, So I have this tpu filament for which I unmounted the normal teflon tube and installed a temporary one direct from the drybox.
On 'load filament' - flex - (I have one second of disturbing noise but leaving that aside for now) the menu says:
" press continue and push filament into the extruder "
when I push continue the machine literally EJECTS the filament from the extruder, it also mentions it on the screen.
When I push filament past  the cogwheel (opened idler) until it won't go any further and after closing the idler and press continue then the same thing happens, I can see that because filament is getting fed back into the drybox
How can I ever get tpu loaded?
Puzzled, Pea
Best Answer by GreenPea:
I take the liberty to answer my own question since I think I won't be the only one in this:
Disabling the side filament sensor worked for me.
Loving the learning curve!
Napsal : 04/10/2025 12:57 pm
GreenPea
(@greenpea)
RE: ejects filament on 'continue' while loading filament
Napsal : 04/10/2025 1:05 pm
