Core One Bed Adhesion - Corners Warp Up
Toxygene
(@toxygene)
Need some help - I struggle to print anything larger than about 100x100 without the corners warping off the print bed - see pics example.
I get this in PLA, PETG, ASA, PC.  I used to get it with the MK4s - then upgraded to Core One and it still happens.
I've tried Brim of various types, slightly changing the print bed temp (5 deg higher).
It seems to get worse with higher fill-rates.
Any suggestions really appreciated.
Posted : 19/05/2026 7:35 pm
RE: Core One Bed Adhesion - Corners Warp Up
Posted by: @toxygene
Try more perimeters (4-5) and a 10-12% gyroid infill. Also, how are you cleaning the build plate?
Increasing infill will only make it worse by increasing internal stress as it's cooling.
Please save your project, ZIP the .3MF file and attach it here.
Posted : 19/05/2026 10:58 pm
Thorough cleaning of the build sheet may be enough - look up threads here on the subject.
Try 'Mickey Mouse Ears'  -  helper_discs in Prusa's gallery, at the corners along with brim.
Avoid grid infill - gyroid should be OK but slow, cubic is often enough at relatively low densities.
Posted : 19/05/2026 11:24 pm
Toxygene
(@toxygene)
Thanks both - Apos for delaye reply - have been away but I'll try the bed cleaning and Gyroid / Cubic infill as suggested this evening.
Model is attached - any other pointers really appreciated.
I've been cleaning the plate with 70% isopropyl wipes, but will get some proper 90%+?
Posted : 02/06/2026 7:37 am
Conrad
(@conrad-2)
I like gyroid for many things and learned that you can enter any number for the density, not just the drop-down values. I very often use 7-8%. Small changes at low values can have a large effect. It doesn't trigger a reslice, so you can quickly grab a drop-down value before entering what you really want.
70% alcohol probably isn't great for removing oils and such. 91% should be easy to get. IMO, alcohol isn't effective on many contaminants so give alternate cleaning methods (detergent) a try. The 70% might be most of the issue.
Don't skip the "absorbing" step where the bed comes to full temperature. Standard profiles?
Posted : 02/06/2026 2:08 pm
