RE: CORE One and soft TPU
Hello,
I have printed without problems the shoe uppers with Polyflex TPU 90A Clear. I use a standard nozzle because otherwise it would be impossible to print TPU on my Core One
My personal experience with flex filament on the Core One:
- I had a really great experience printing with Prusament TPU 95A!
- Then I tried Polyflex 90A… what a nightmare !
I dried the filament as much as possible, tested a bunch of settings, and in the end, I just gave up. but I’m still curious if anyone else had luck with this specific filament...
Hello,
Thanks Daniel, I will change the nozzle, I tried with a CHT/HF...
I had not considered that HF hardened nozzle would make a difference. That's what I'm using.
Is your printer modified with the improved idler?
I am looking forward to INDX because that will allow you to actually print TPU onto other materials while you’re actually doing the print job.
one of the most ironic things was me printing up a coreboxx on an H2D so that the pulley could be printed directly with a soft material on them for the filament spools…
with INDX the path to the intruder will be far better and easier to use than even the AMS 2
This is an example of what I was talking about… and with INDX this will actually be possible. Whereas with my core one, before I sold it because of my complete and utter dissatisfaction with the MMU3 and the horrible support from Prusa, this type of printing was completely impossible.
(and yes, I did attempt to get the military to blow it up… And they were willing to use 100 g of high explosive… But the university was unwilling to risk their high speed camera… I was THAT annoyed with support….)
hahaha, having many hundreds of hours on a MMU2S on MK3, I never ever expected TPU to work in it. TPU prints fine on the XL and I can do multi color/multi filament things. PLA works pretty well as a support material for TPU things. I'll wait to see what experience others have with the INDX before I consider dipping a toe in those waters.
no, in my case it was all specifically core one.
printing TPU in the core one worked like a dream for me. It was more a matter of the multimateria aspect of things which just was never gonna work. in the case of the MMU3 with the core one it just sucked in general… plus it’s usually limited when it comes to multimaterials that are not TPU (you’re only supposed to use PLA or PETG with the MMU3). I really have high hopes for INDX
yes, the MMU was never more than a kludge at best. the 3.x firmware really helped a lot, but at that point I had a 5T XL and never looked back.
Ok, I forgive the Ninjaflex. I am getting much better results from the brass nozzle. I didn't think it would make a difference if the temp was a little increased on the hardened one.
There's room for improvement but the filament is flowing at least (with the mods).
With all of them, I found it had to be dried beyond belief…. and then the core one would work beautifully. I would just get it manually started by pulling the PTFE tube from the print head and then once I got it started just it worked.
