CORE One and soft TPU
Stránka 5 / 5
ssill2
(@ssill2)
RE: CORE One and soft TPU
yeah now that you mention it, I like the fact that prusa provides the upgrade path too.   Both MK4S and Core One printers started as MK3S'es.  I'm still waiting on the next rev of XL to come out.  It's been long enough, and it's about time they did.  Mine shipped assembled as 5 tool and with .6 nozzles lol 18+ months of waiting after preorder haha.
I'm glad you're taking precautions with that hd2.
Cheers!
Napsal : 19/08/2025 12:32 pm
PE1
 PE1
(@pe1)
Posted by: @scott-18
Hello!
I'm currently trying to print TPU (step step from 95A, to 60A) and 85A was very difficult to load without removing PTFE and printing directly from the top extruder.
Does anyone have a tips for that?
Next step will be 70A and then 60A, but I think I will have to modify filament guide inside the head with something like THAT.
I will keep you in touch, 85A Ninjaflex was printed easily just by unscrewing idler tension a little.
I wish someone would post a video on YouTube about how to load TPU into the Core One.  It's difficult to follow the process in pictures for me personally.  However I appreciate you documenting it here.  At least I know I'm not crazy.  🙂
Napsal : 04/10/2025 4:42 pm
Posted by: @pe1
I wrote a Printables article on how I print TPU Air which is a soft TPU: Printing Siraya Tech Flex TPU Air on a Core One in order to do this I had to install the two mods mentioned in the article and I remove the Bowden tube and feed directly into the nextruder.
That said, I've been able to print 95A without the mods and feeding past both filament sensors. The softer stuff (like 85A and below) is hard to impossible without these mods.
"Some filaments feel the rain, others just get wet"
- Bob Marley
Napsal : 05/10/2025 2:42 pm
LordMelkor
(@lordmelkor)
Worth noting I’ve printed 85A without mods on the core one unmodded. It’s a little annoying to feed the filament but it’s definitely doable.
it was a lot easier on the MK3 series.
Napsal : 05/10/2025 4:18 pm
ssill2
(@ssill2)
The real benefit to the mods is the fact that you don't have to open your extruder and untangle the tpu from around your gears. The profiles for things like ninja flex are entirely too high MVS. I've found to get reasonably reliable prints with things like ninjaflex and chinchilla you need the mods to so there's no room in the filament path, and you have to go SLOW. I have the mods installed for my xl, my mk4s and my core one. The core one is not at all tpu friendly out of the box. My baseline MVS for ninjaflex and chinchilla is 1.19. It's slow, but it's reliable.I've got a second mk4s-> core one upgrade sitting here that I'm hesitent to do until I've had some more time with the core one. After some initial mishaps with the first core one upgrade though, I've got it printing pretty well. Tpu seems to be an afterthought on the prusas though. Those mods should be standard issue on the prusas. I've done some 92 and 95A prints on the core one with just the extruder mods, no filament sensor mods and that goes ok. I really find the idea of having to fiddle withe bowden tube just to print tpu annoying though. it's not bad on the XL since you just unscrew it and help the filament load and the put screw the bowden tube back in. the xl doesn't have that plastic part that fits over the connector.
Napsal : 05/10/2025 4:38 pm
LordMelkor
(@lordmelkor)
The official ninjaflex profile actually worked fine for me. No tangles.
but one parameter I did change based on experience from mk3 days is de-retraction speed. Had to sl9w that down. Everything else can be default
Napsal : 05/10/2025 5:34 pm
ssill2
(@ssill2)
yes, the retraction and detraction speed I set to 10. when there's extra room inside the extruder(i.e. the mod isn't installed) that' more chance to get tangled up in the gears. I may not increased MVS once I figured that one out. I never ever look for fast when I'm printing tpu, the 1.19 puts it on the bottom end of the ninjaflex recommended print speed, 3.0 is quite a bit faster than recommended speed. I also go 3-5C over the top end range because I print with the harden steel nozzle and not brass. Having gotten it to work pretty well on the xl, mk3, mk4 etc, there's not much magic for the core one. I wanted to get to the point where I didn't have to adjust the idler tension screws to switch between tpu and everything else, and I've gotten to that. I just wish the prusas didn't require so much fiddling and modification from the stock to reasonably handle tpu. If I switch my other MK4s to core one I'm probably going to bite the bullet and do the filament sensor mods and not just the bogie parts. The bogie parts, IMHO are a must have if you print with tpu at lot.
Napsal : 05/10/2025 5:52 pm
Posted by: @ssill2
The filament sensor mod (with magnets instead of spring) is easy enough and makes a lot of sense. Not sure why Prusa doesn't use this approach. The bogie mod is not just for TPU but I've found better overall for various extruder gear issues I was having.
- Bob Marley
Napsal : 05/10/2025 6:06 pm
1 lidem se líbí
ssill2
(@ssill2)
yeah, I liked the bogie mod enough that I printed 7 sets and updated the XL, the MK4S and the CoreOne(that was upgraded from MK4s).  prusa should make that standard issue.  I don't see any reason at all you wouldn't want your filament guided precisely to the nozzle tube, especially for TPU, but in general for any filament.  Was a good chance for me to print PC-CF the first time.  I do plan to do the filament sensor mod as well.  I' was hoping for a hardware refresh to the XL so I could update the sensors in those too.  One of the very first things I did when I got the XL a couple years ago now was to take the ball bearing and spring out of the filament sensors by the spools since they created a TON of drag on Tpu and made it underextrude.  why would prusa keep making the same mistakes.... lol  oh well.  I still like my prusas.
Napsal : 05/10/2025 6:25 pm
1 lidem se líbí
Ckobar
(@ckobar)
Hi everybody. Regarding the sensor mods.
I modded both sensors.
The mod for the side filament sensor works like a charm and it‘s done much easier than expected. I printed a lever with a slightly bigger „magnet“ hole. When testing with a spare one I noticed that the weight of the lower magnet is basically enough to work properly. So I left the upper magnet but put some pieces of lead into the hole.
I used only one magnet for the mod on the nextruder sensor. 2magnets as suggested had to much resistance in my opinion. So I added only one opposing magnet but put a small piece 2mm plastic behind. That way the sensor opens reliably,but now my setup is soft enough to push the Prusa tpu all the way through without disableing sensors or disassemble the tube
Napsal : 18/10/2025 3:40 pm
Stránka 5 / 5
