Can the Core One print PETG-ESD filament?
Neal
 Neal
(@neal-2)
I am interested in making some small boxes for circuit boards.   I see that Polymaker and some other vendors make PETG-ESD, which I know will need a hardened nozzle.    I don't see any profiles in Prusa Slicer for a PETG-ESD filament that I can purchase in the USA.   There is a profile for a EU company called AddNorth.
Has anyone printed with PETG-ESD on the Core One, and if so, what product and slicer profile did you use?
Thanks,
Neal
Opublikowany : 18/10/2025 4:43 am
Brian
(@brian-12)
RE: Can the Core One print PETG-ESD filament?
Yes, but you need to use a . 6mm nozzle to prevent clogging.
Opublikowany : 18/10/2025 12:44 pm
Brian
(@brian-12)
mnentwig
(@mnentwig)
Just stating the obvious, but typically consumer electronics assemblies are not made from ESD-compliant material.
If the problem really needs conductive plastics, no can do. But it's non-standard and expensive.
Opublikowany : 18/10/2025 1:20 pm
Posted by: @neal-2
If you can't find a manufacturer that provides a profile you can import into PrusaSlicer, you start with something reasonably close, modify it with the manufacture's configuration and then save a user preset. If you use some other manufacturer's preset out-of-the-box then you may or may not get a decent print. ESD filaments are generally impregnated with carbon fiber so (as you pointed out) you'll need a hardened nozzle. Also I would recommend 0.6mm or larger and not high flow. It's also super expense, in most cases $200/kg.
Opublikowany : 18/10/2025 3:23 pm
Neal
 Neal
(@neal-2)
PolyMaker has a PETG-ESD filament, 1/2 KG spool, ~$33 USD:
REF: https://www.amazon.com/Polymaker-Fiberon-PETG-ESD-Filament-1-75mm/dp/B0D4QB1DGR/?th=1
Neal
Opublikowany : 18/10/2025 4:08 pm
Posted by: @neal-2
Neal
OK, then if you use this be sure to follow the recommended settings:
https://us.polymaker.com/products/fiberon-petg-esd
Printing Temperature: 250˚C - 290˚C, Bed Temperature: 70˚C - 80˚C, Printing Speed: up to 500mm.s, Fan: OFF, Retraction Distance: 1mm, Retraction Speed: 20mm/s, Drying Settings: 65˚C for 3h
Opublikowany : 18/10/2025 4:26 pm
