ASA fan settings
Jan Eickhoff
(@jan-eickhoff)
ASA fan settings
Hi, at times struggling with prusament ASA warping for difficult objects (tall, walled) - that at 55C chamber temp.
The print deforms the brims and pulls them half off....
How low are you setting the fan to minimize warp but maintain a good perimeter surface?
Does the perimeter surface degrade if the fan rpm is reduced?
Thanks,
Postato : 14/06/2025 3:30 pm
Artur5
(@artur5)
RE: ASA fan settings
Specially overhangs and bridges would degrade with reduced rpm. It depends of course on the volume of air delivered by that specific fan. Some fans will  cool ASA perfectly at 30% rpm and others might need up to 50% or only 20%...
Postato : 14/06/2025 6:10 pm
Shushuda
(@shushuda)
Fan speed Min 10% Max 10%
Bridges fan speed 20%
Disable fan for the first 5 layers
Disable dynamic fan speeds
Everything prints perfect, including bridges and overhangs, and no longer warps. Chamber 55-58C.
Postato : 17/06/2025 5:06 am
2 persone hanno apprezzato
Jan Eickhoff
(@jan-eickhoff)
Will try that, thank you!
Postato : 17/06/2025 5:44 am
