0.6 HIGH FLOW NOZZLE
CJWizard
(@cjwizard)
I am printing some simple parts with a PC Blend and 100% infill.  The first two parts printed well.  The third print started looking bad and the print head started clicking.  The filament was not flowing through the hot end fast enough.  Is there a recommended set up for the 0.6 nozzle?
Posted : 19/01/2026 12:15 pm
How big are the parts? I would never use 100% infill with PC Blend. I would use 8-10% gyroid infill and increase the number of perimeters instead. At 100% it will warp unless the parts are very small. Anyway, my guess is you got a heat creep clog. Can you attach your zipped 3MF so I can have a look?
Posted : 22/01/2026 5:24 pm
CJWizard
(@cjwizard)
RE: 0.6 HIGH FLOW NOZZLE
I am printing a 6" diameter roller 3/4" thick to use in a roll forming bender.  We are doing some R&D on some aluminum extrusions.
Posted : 26/01/2026 6:19 pm
